TFPro test kit. First time using - didn't find it complicated. Heading to pool store to buy some liquid chlorine to have on hand and want to see their results as well. Here are mine, and my plan - thoughts?
FC: 5.5
CC: 0
TC: 5.5
CYA: 40-45
PH: 7.8
TA: 170 (conducted twice, to make sure)
CH: 550
Goal: I want to reduce my TA and PH to avoid PH going past 7.8 in the next few days. TFP says don't adjust TA "just to adjust TA to a target number" unless I have a problem. I feel like my PH is a little all over (strips & pool store history from last year prior to test kit coming - PH high last year was always issue).
Pool Math app: tells me 64oz (half gallon) of muriatic acid (34.5%) will lower my PH to 7.1 and drop my TA by 11 to 159.
Thoughts on continuing to get TA down without tanking PH? Necessary? Monitor by testing and keeping data to see how PH is actually doing?
Notes: no water features to aerate; I do not have screw in jets to "change the direction" of the output - our return jets are two holes. Gunite pool, 22,5000gal, chlorine (no SWG). Very hard water in our area. TFPro test kit. We did just get some rain - but by no means a lot (maybe 1/4" if that).
FC: 5.5
CC: 0
TC: 5.5
CYA: 40-45
PH: 7.8
CH: 550
