ok, first, we recommend to report CYA in increments of 10, as seen on the test vial. The CYA scale is logarithmic, So it is not straightforward to interpret a reading between, say, 40and 50. If your reading is between 40 and 50, then simply round up and report it as 50. Then, use the FC/CYA chart to determine your chlorine amount for daily use or slam based on the higher number of 50. Rounding CYA up also results in you using higher chlorine amounts for daily use and slam. And, with chlorine, it’s typically to err on the side of using a bit more. We are trying to prevent or kill algae/organics.
So In your case, your reading is between 40 and 50, so consider it 50. Chart says slam level for a CYA of 50 is 20ppm chlorine.
