Adam.
0
cooljul- what is your objective?
Help you friends with a possible solution that involves rolling the costs back on the inspector or realtor?
Or a DIY fix where you get into the system and start testing????
I can tell you what you need to do to pressurize the solar loop, but once water starts spraying all over the roof (and youve destroyed the evidence) what is your plan then? I would not touch it until you preserve the ability to file a claim.
In the first post, the second picture: are the 2 caps glued on?.... do the two pipes that go out of frame run up to the 'bottom' of the solar panels and the top of the panels (that are pictured on the roof in a later shot)??
