10-4
Slam level for cya of 40 is 16ppm
Be sure you are thorough with the
SLAM Process this time around.
*Check & scrub every nook & cranny where algae may hide (light niches, steps, drain covers, ladder handrails, skimmer throats/weirs, abandoned lines, autofill, overflow drains, etc.)
*If water can go there, algae can thrive there.
*Run slam level water through all water features & lines for at least a couple hours a day during the
SLAM Process.
*Brush & or vac daily (this breaks up biofilms that algae uses to protect itself from chlorine)
*Backwash/clean filter when pressure rises 25%over clean pressure.
After passing ALL 3 end of slam criteria:
CC is 0.5 or lower;
You pass an Overnight Chlorine Loss Test
AND
The water is clear.
(Crystal Clear w/no algae dead or alive)
You should then proceed to the Mustard Algae protocol for 24hrs if you indeed suspect you have mustard algae.
Today We are going to show you how you can get rid of mustard algae in your pool. By following the steps in this guide and with no expensive chemicals.
www.google.com
After this you may want to maintain MA minimum for some time
