Hello to all. Looking for some help. Had recent repair of broken return pipe to spa under deck. Repair (seems) fine. No longer loosing water from pool/spa. However, spa will not hold water when pump turned off, pretty rapidly leveling out with pool. Happened a few years back, and a quick change of the check valve fixed it. This time, I swapped in 2 new check valves to no success. Doesn’t seem to be the valve. During the repair, pretty sure my valves were adjusted when locating the leak. I have read that if the valves are not set properly, this also can affect the spas ability to hold water (?). Problem is (for me), aside from the valve that regulates flow for main drain versus pool filter (the valve on the far right of the picture in the foreground to the motor/pump)I have no idea how the other valves should be set. And, to add to the mystery, the labels on the related piping has long faded off. So I am hoping you all can help me out.
Goals:
1. Label pipes
2. Set valves in correct position.
Currently run the pool in “pool mode” and want the spa to continuously overflow into the pool.
I have included pictures to help out. One of the whole setup, and a left and right “closer” up. Note: the spa heater needs to be repaired (hasn’t worked in years). Also when the pool shuts off on the spa is draining, the valve right in front of the automatic chlorinated (also not working) gives an audible repetitive “click” sound until the spa levels out with the pool.
Any input is appreciated. Thanks!
Goals:
1. Label pipes
