Screen logic 8 Easy touch system with spa side remote. I'm having an issue with the settings. I added the spa side remote4 a while back. So, when I push the spa button it goes into spa mode and starts to heat up to my preset temp of 102. (good). I added jets to the spa side remote 2nd button thinking this would be a nice boost as I set the jets to a higher rpm. I was thinking that when the heater got too hot I could just shut off the spa and run the jets without heat. But what happens is when the spa mode is turned off the jets go to both the pool and the spa. So all the heated water circulates into the pool and vice versa. where did i go wrong? Also I could just run the air blower on the spaside remote instead of the jets but I cant seem to figure out where its at to do this?
