I have this old pump. For the 2 years we've owned the house it's worked well. Last Week it shut off at night during a storm due to a tripped breaker. I reset it and a few days later, same thing. Checked the timer and it appears fine (it's inside at the panel). Cleaned the basket, nothing major in there. Checked the gfci outlet at the switch. Test failed. Took it apart and pretty rusted. Replaced.
During testing of new outlet I notice I get a hum at the pump and it doesn't fire up. I try a few times and she turns over. I'm thinking this is why the breaker is tripping when the timer kicks on? I read about cleaning the impellers, but with this setup I stick a screwdriver in there and just hit a wall. Doesn't appear to be anything there. No fins to manually move and no debris...
When the pump is running the pressure and everything is fine, so my next step (as I test how the timer works on the new outlet) is to take the pump apart but I'm not sure the best way to do this... and I don't want to ruin this semi-functioning pump without having a new one ready to go. Should I be worried about non-replaceable gaskets? There's no manuals anywhere out there for this pump that I can find.
So, just undo the clamp? haha
site says my pics are too big, so pics are here:
pics of the setup here Pool - Album on Imgur
