jumpinjackieflash said:Shaf77 said:jumpinjackieflash said:Can you cut the trees down? I see what you mean, the front part of the lot is smaller than the back half. If you're going large, that is your best option. How often does water flow down that swale?
I guess there is an option of cutting down maybe the first tree.
But what about the swale?
Well if it's a drainage feature that runs through all the yards, you can't block it, can you...How does your plan allow for it when it's full of water? How often does that happen in the summer? Or the winter for that matter.
At our previous house, we had a swale between us and our neighbor that drained both yards very nicely. We went on vacation for 3 weeks - they decided to construct a deck on that side of their house. They blocked the swale, I guess with the concrete they put their deck posts into, and blocked the front where it used to drain out to the street. The first time it rained, our side flooded with all the water from THEIR yard. I was livid. We ended up having to install a drain out to the street when we built the pool.
At least then, their yard flooded and ours didn't.
The swale collects water from the first half of our lot and drains to the right (facing the back) to the next couple of lots that have the exact same swale to a City drain.
The home to our left also has the swale that drains to us and continues on.
Cutting the tree may be an option, but the swale is still there....
