- Mar 2, 2022
- 54
- Plaster
- Pentair Intellichlor IC-40
I wonder if someone could tell me what to do regarding salt in the pool. I somehow found the calculations to help me add salt in the pool on here somewhere (I added 6 bags about 3 weeks ago). After that, the chlorine level was 10, so I decreased the percentage of salt to 25%. I'm now running my pump from 10:00 a.m. to 8:00 p.m. I run on high because we have a waterfall and bubblers. Chlorine is now 6, but my salt test is 2400. Shouldn't it be 3200 to 3600. Do I need to up the percentage and to what? How do I get my salt level to be in the right range? Here's my test results as of yesterday:
FC - 6
pH - 8.2
TA - 60
CH - 300 (adding two bags of Calcium Hardiness tomorrow)
CYA - 70
Salt - 2400
Borates - None
Water Temp 81
Thank you!
LaDonna
FC - 6
pH - 8.2
TA - 60
CYA - 70
Salt - 2400
Borates - None
Water Temp 81
Thank you!
LaDonna
