- Jun 1, 2022
- 15
- Plaster
- CircuPool Core-35
Hi all! I've been trying to get my mother's SWG pool in order this summer so it's a bit more sustainable for her to maintain between when I visit. The stats in my profile should be accurate but here's a rundown of the system and current chemical levels:
~15,300 gal salt water pool
Gunite and plaster (in ground)
Sun: in full sun from about 11 - 5
SWG: Circupool COre35 running at 50% from 8-6 7 days/wk
Latest test:
FC: 1.5
CC: 1.0
TC: 2.5
pH: 7.8
TA: 110
CH: 300
CYA: 47
Salt: 3300
Temp: 85.1
CSI: 0.18
pH has been high (8.3 avg) for months and I've been dumping in Muriatic acid to combat that. For whatever reason, I'm having to add about double what Pool Math suggests to get pH to start trending down. My plan was to lower pH to 7.2 and then aerate (with hot tub blower) up to 7.8 to lower TA at the same time. So far, 7.8 is the lowest I've gotten the pH without dumping over a gallon of acid in.
Likewise, CYA has been low (averaging 20). Pool Math suggested 2 gallons of conditioner which only raised it to ~50 as we see now. Apparently I need to go buy more. I was also noticing some light green algae on the walls which I was able to brush off easily.
I was doing some reading and it seems that since my pH is high, CYA is low, and TA is high, a chlorine tablet might do exactly what I need. I have some chlorine tabs here (don't know why) that I can certainly use but I wanted to run this plan by the brain trust first. Is there anything I'm missing with using a chlorine tab?
If the chlorine tab isn't the best thing to do, what's a better method? And why does it seem like I need to dump 2-3 gal of Muriatic acid in to get pH down to 7.2 to aerate back up?
Thanks!
Latest test:
FC: 1.5
CC: 1.0
TC: 2.5
pH: 7.8
TA: 110
CH: 300
CYA: 47
Salt: 3300
Temp: 85.1
CSI: 0.18
Thanks!
