we just finished our 14k gallon pool done all with mosaic glass tile and epoxy grout in Canada. We have an auto cover and plan to keep the pool above freezing over the winter with occasional use using a propane heater. Currently pool is 24C using primary source of heat from an electric heat pump (should lose its efficiency now that we are starting to see freezing weather).
Chemistry is:
Ph 7.4
Fc 6.5
TA 90
CH 300
Cya 50
Salt 3000
Borates 50
I’ve been playing around with the csi calculator and looks like if I bring up CH to 700 it’ll bring the csi number within range assuming I’ll keep the pool over 10 C. Thoughts on this plan?
We installed in ground cleaning system from Hayward which seems to work well aside from one small area. Should I be brushing the tile once in a while?
Another question; at what temp would the salt chlorinater stop producing chlorine?
Thanks for all the help, this forum is incredible!
Chemistry is:
Ph 7.4
Fc 6.5
TA 90
CH 300
Cya 50
Salt 3000
Borates 50
