Help!
Yesterday, as we were having a new fence replaced, I noticed the pool wasn't "on". I asked the fence installer and he said he didn't do anything. they did plug the circular saw into the gfi outlet (and removed the aquabot plug, but I can't imagine this caused the issue). I figured I'd look at it after the fence guys were finished. So last night I went to turn the pool "on" (pump/filter) and it wouldn't turn on. the check system light was on and in the window, it read "VSP Comm Error". I turned off and then on all the ciruit breakers, but to no avail, I cannot get the pump started.
I have a 60000 gal IG pool with all new equipment (2 years old). I have a Tristar VS pump and a Swimclear C7030 (8 cartridges) filter, a salt generator, and aqua plus controller and solar heat, all installed in 2014.
So what do I do? Do I need an electrician? call the pool company that did the install? Is the pump gonna be so expensive to investigate and fix that I should just replace it? Anything I can do to help myself? Any ideas are welcome.....
