Installed a
V-Green 1.65 HP Round Flange 56J Variable Speed Motor - ECM16CU
Item# ECM16CU
ran for 2 seasons ago, and worked well. Last fall when trying to close the pool I lost pressure. The pump runs, but the basket seems to run out of water, and the pump slows, water fills and the pump speeds up-- like it's losing prime? When it finishes high-speed start-up, it runs a bit more constant, but with little pressure. It is the motor, a leak, clogged line (I've tried to blow out the suction, line and ran the pump straight to waste). I did open the pump to check for debris, seemed fine, The impler looked ok.
Any ideas
Here's a video showing what it's doing
thanks
Item# ECM16CU
Any ideas
thanks
