I have a Hayward H350 connect to a Jandy PDA Aqualink. I have no error codes and the display reads as it should (bo & standby as connected to Jandy). When switched to low speed or pump off the display changes to LO as it is supposed to do. When I turn the heater on I can hear the relay in the Aqualink box click. I have checked all 4 fuses on the Hayward control boards and none are blown, and I read voltage across all the fuses. However, I get nothing beyond that. What is the next troubleshooting step? If it is the transformer can I check that with a standard volt meter? I think the next step in the sequence if the blower should kick on, but obviously it is not coming on. I hated to stick the wires with the volt meter to test and leave small holes in the wires, as there are no open connections that I see to land the volt meter posts on.
Any advice is appreciated.
Thanks
Thanks
