- May 18, 2015
- 339
- Plaster
- CircuPool RJ-60 Plus
I never really thought about it overflowing unless I did it intentionally to push surface crud (pollen, dust…) over the spillway, into the pool and right to the nearby skimmer.
Here is a pic of it this evening. The pump is on. The water is just below the spillway but about 1/2” higher than the pool. You can see the white equalization tube in there as well.
