It's been a while since I've been on here. Pool is 20x40x10ft.
Short version, muriatic acid won't remove limescale, calcium deposits from pool walls. I don't know what else to try.
Back story, the house we bought had been sitting for 2 years when we bought it in sep of '19. The pool was a swap. I was able to get it clean and usable by June of '20. There was always a problem with algae buildup in the deep end, it just would not come completely clean. Fast fwd to March of '22. I bought a new pump, so I decided it was best to start all over and drain the pool, acid wash it, paint it. Problem is the calcium buildup is so thick on the walls that muriatic acid won't take it off. It just runs down the wall. Where it has time to sit on the floor, it comes off great. I've tried vinegar, industrial descaler, chlorine. I tried renting a 4k psi pressure washer, nothing. I tried a steel bristle angle grinder, nothing. The only thing I going found to work moderately, is (please don't judge me), burning it off with a pear burner and propane tank, but it won't take it all off. Pictures are of the walls and floor where it has run down and dissolved the calcium buildup.
