I started opening myself last year and getting the pump to prime was tough. This year I'm having the same prime the pump challenge, so thought I would look for suggestions.
The pump is about 75' from the skimmer, and probably about 2-3" higher in elevation from the pool. The spa is much closer and I had no challenges priming this year. In the attached picture of the pool, the equipment in back left next to the house. I've removed all the plugs and raised the water level. There is a check valve right in front of the pump, I'm wondering if that is helping or hurting me. First prime attempts didn't work, so then I tried removing the check valve and filling the pipe with water until it stopped going in and then put the check valve back. Still no luck. I guess I could have tried priming without the check valve?
I also read about moving the spa/pool diverter valve back and forth to try and get air out of lines and pull water up the pipe, but no luck. Although I feel like that trick helped last year.
Priming the pump during the normal season is never this challenging. It seems to only happen when I open. I'm guessing the long run to the skimmer is not helping me.
Attached pics of my setup. Any suggestions would be appreciated.
Thanks!
Thanks!
