I am installing a 12' x 27' x 5' vinyl liner pool and need advice on water circulation. My PB provided the following schematic, to which I added our water feature wall (will not remain on all the time). There is no main drain.
1) Skimmer:
1) Skimmer:
- Is one sufficient for my size of pool?
- As drawn, the skimmer is out of site lines from the rest of the back yard and opposite the water falls, but it is not facing the prevailing winds..
- Assuming the indicated returns are close to the surface, can I get away with simply adding a deep return one of the unused corners and directing in the same clockwise current?
- Would it be better to have two shallow returns and one deep, or vice versa?
- Will the return drawn near the stairs be sufficient to clean the stairs or should the be an additional return closer to them?
