Help... pool heat pump
Kiddo44pct
Active member
Apr 20, 2017
33
Nyc
picked up a used rome pool heat pump model 75..no manual..dont know which side is in and which is out
Here is picture..thanks in advance
It is going to be hard to install it or maintain it without the manual.
If you have a basic understanding of how a HP works you can probably deduce which is the intake by where the waterflow sensor is. I see an electrical diagram on the top of the control panel that may give some clues. You have to look among the plumbing and identify common parts. All HP's basically work the same way and the reverse of an AC system.
