Extensive internet search found very little in actual aluminum CP-2 bullnose repair. For background i consider myself a modest DIY'er, most typical pool equipment upkeep, I perform. Avid researcher and info junkie. Im a former military jet maintainer and former powerplant maintainer and now graduated to a desk job. I'm 50 something and pretty attentive to maintaining my property and everything on/in it. What I am not is a concrete guy or knowledgeable about the finer points of pool structures. I have learned a lot about basic pool construction of the last couple days but far from confident in attacking thos issue. I have a friend that is a pool guy, but he's more of a builder than a maintainer. Our Pool was built approx 2003. We purchased the property in 2015 (we are the 3rd owner) no inspection possible as it was winter. Liner professionally replaced Sep 2016 (was told no need for coping replacement at that time). Concrete deck was "resurfaced" by local contractor Mar 2017. (Thin layer ground off, cracks v-cut and filled, smoothed skim surface installed, and new cool deck layer applied. Then painted with concrete-type paint.)
Current state, coping has one segment separating, while the remainder of the coping is in good condition and liner has at least a few years before, in my estimation, needing to be replaced. For these reasons, I am looking toward repair, not replacement of entire coping assembly. The other problem/worry is not knowing the timeframe of increased possibility of major failure of coping/liner retainer.
Initial indications were noticeable 2020 swim season. See attached photos for progression, if interested.
Root cause appears to be the crack extending from edge of concrete to pool's edge combined with central mid-west freeze thaw cycles. Resulting in what i assume to be detachment of coping anchor points thus the weight of water/liner pulling coping inboard at increasing increments through winter seasons but more gradual in warmer seasons. My ignorance delayed my remediation of the crack. Hindsight 20/20 and money saving measures gone ugh! The affected coping segment aligns with pool structure area that transitions from shallow to diving depth. It goes without saying that addressing cracks should be and will be a priority.
Best case - Hoping to manipulate coping back into position and secure.
Question - Is it possible to cut back just enough (a few inches) re-secure coping anchors, then backfill with concrete repair material? If so, is this possible with liner in-place and water up to typical level. What are the drawbacks and risk associated.
Worst case - replace deck
I'm aware of the typical repair of cutting concrete deck back approx 12" removing existing coping and concrete material (in conjunction with liner replacement). Install different style liner retention track, install stone/brick in cutout section around entire pool. Again existing liner and remaining coping serviceability weighs into options.
Looking for:
- experiences in evaluating options
- attempted repairs and lessons learned
- professional opinions on different possibilities and ramifications of each.
Thanks in advance for any helpful info anyone can provide.
Please look past the water conditions on photos as these are typically taken soon after pool cover comes off.
![20240407_082318.jpg 20240407_082318.jpg](https://www.troublefreepool.com/data/attachments/297/297818-e0dfb18874795d756316403bd3db272b.jpg)
![20240407_082249.jpg 20240407_082249.jpg](https://www.troublefreepool.com/data/attachments/297/297819-b685a61cb1ca954e5bc24450d533d6b4.jpg)
Looking for:
