Okay..how do I lower my CYA? Do I need too? I was reading pool school and found different information on what my levels should be...
Answers in red
Vinyl with Bleach
FC 3-7
pH 7.5-7.8
TA 70-90+
CH 50-300
CYA 30-50
Chart found here:
pool-school/recommended_levels
These are good recommendations. Many, including me, follow them almost religiously. Me? I'm OCD about it.
So, what should the levels be for my pool??
To be able to answer this, you need to open the 6-way and do the CYA test, and post what you read.
I was told that the chlorine shouldn't go over 4.0ppm, that it would burn your skin if you swam in it.. Is that wrong?!
In most cases, that is wrong. I don't know if it is still use in medical therapy for certain skin conditions, but Doctors used to recommend bleach baths, with the actual level of the chlorine upwards of 100 ppm or higher.
I just tested my pool again, at 7:1 x 8. It read 1.5, so it is really 12.0. It doesn't have a very strong bleach smell, when I tried testing it the normal way the chlorine level was so dark (which is why I did the 7:1 ratio). So, it has lowered quite a bit during the day (it was a 32.0 this morning)..is that normal??
