Went to check on a pool today which we decided to leave uncovered for the winter. Not sure I'd do that again because when you'd think you've eliminated every last leaf somehow a good bit is back in the pool when the fall had passed by a good bit. The water is looking greenish but I'm not too concerned about it except I'd want to be up and running mid may to have an easier slam before the water hits 60°. As you can see in the pictures a liner tear up at the bead level developed, well above mid skimmer and I have a pool cover pump on the second step keeping the water well below. Liner is about 6 years old with no other problems. What would be the best way to save this and repair it to get by another full season or two.
