Hi all
I need help! I've been calling pool stores and getting different answers. I Have perflex EC50AC. My filter is 5 years old. I have never had a problem until this week. I have been trying to open my pool and I have the following problems
Filter runs at 12 pounds at first then quickly rises. If I bump the psi will go down but it will go back up withing an hour hitting around 30 psi or over. I then notice a leak at the top of the filter in-between the metal band. I have removed and cleaned out all the DE 4 times already and it continues to do the same thing. Lastly I soaked the girds in cascade overnight rinsed then off then I soaked them in a muriatic acid solution overnight
I reassembled the filter added De and it does the exact same thing. Within an hour or two the psi is so strong that it begins leaking at lid.
The fingers look like new after cleaning them. I don't see any cracks. At this point I don't know if I should have someone look at it to repair or purchase a new one. It's the Hayward perflex De EC50DC
One plays is asking $75.00 to deep clean and then check for any broken and or defective parts.
The pool last week had heavy algae it was dep green I shocked it and added banish. I tried filtering and vacuuming as much as I could between the filter issues. There is no more green tint in the water, but does have some cloudiness. There is a little alagie in the bottom that I need to vacuum.
Thanks for the help
Thanks for the help
