Its not good for a gunite / plaster pool to remain empty any longer that you just have to.
Plaster is formulated to be underwater, it NEEDS to be underwater.
A couple days max, and the sunnier it is, the more ill effects on the plaster. If you have to leave it empty a few days, put a water sprinkler on it for a couple or 3 hrs a day to keep it wet.
Also, be aware of the possibility of ground water under the pool. If you have a high water table, or saturated ground, the hydrostatic pressure under the pool can pop the whole pool out of the ground, ruining it. Lots of pools are installed with Hydrostatic vavles located in the main drain. If your pool has one, open it before you get more than about 1/2 of the pool water drained out of the pool.
