I am in need of replacing the impeller on my SP3215X20. It has a 2HP "Max Rated" motor. The current impeller in it is a SPX3215C. However, in the manual (https://www.hayward-pool.com/assets/documents/pools/pdf/manuals/TriStar.pdf), it lists this part as being a "Impeller for 1 ½ HP with Impeller Screw". When I go to the parts diagram on Hayward's site (Hayward | TriStar Max Rated Pump | Replacement Parts Diagram), it lists the SPX3215C as being correct stating it is a "2 HP MR Impeller w/ screw". When I click on that link, it take me to the part where it is named "Impeller-1-1/2Hp W/Screw". I am getting a bit confused. Not sure if I should just replace it with the same part or if Hayward realized it wasn't optimum for 2HP and down-rated it. Unfortunately, they do not list another part for a 2HP Max-Rated pump. The only other one I see that may work is SPX3220C which is listed as "Impeller for 2 HP with Impeller Screw (Full Rate)". Can anyone help?
