Hello,
First season with a pool that came with the house we just bought.
I think I’m getting close to getting things right but wanted some recommendations with chlorine and CYA.
I bought a taylor K1004 test kit before coming here and didn’t realize it didn’t test CYA. Bought strips for CYA and also brought my water to the pool store just out of curiosity.
I’ll buy the $80 kit if I have to but was hoping I could get away without it since I already spent $30 on a test kit.
I’ve shocked my pool the past 2 nights by adding 80 oz of liquid chlorine per the pool math app.
Here are my current levels using my test kit:
FC: >.5 (color turned just barely pinker than clear)
TC: .5
pH: 7.2
TA: 60
Result from the pool store said CYA is 5 ppm but the test strip looked more in the 30-50 range so now I feel like I don’t trust either of those and will need to get another kit (can I buy just the CYA testing part since I already have a kit for Chlorine and alkalinity?)
My pool water looks clear and lovely.
I do have a chlorine tablet floater with two 3” tabs in there right now just because since I’m just starting I thought I’d need to up my CYA. I know it’s not the best way to add chlorine in the long run but should I leave it in for now?
What would be your recommendations?
It’s warm and sunny today so I’m worried if my CYA is low adding any liquid chlorine right now would be useless. Is that a correct assumption or should I add chlorine before night time?
I bought some CYA and I think I’ve got all the proper chemicals I’ll need, I just wanted to hop on here and ask for some experienced advice.
Thank you all in advance!
TC: .5
pH: 7.2
TA: 60
