Hello I am a new pool owner with a salt water system
D,
Welcome to TFP... :shark:
You need to tell us more about your pool..
How big is it.
What equipment do you have
Is it an old pool, but new to you, or is it a new pool.
Does it have water in it now?
Is it an above ground pool or an in ground pool?
Reactions: Mdragger88
Thank you so much. I understand that I need to add the stabilizer first. Can I use shock for the chlorine or must I buy liquid chlorine on top of adding the salt?
It said to add the salt and let it dissolve for 24 hrs prior to running the salt system.
Consider getting a proper test kit as discussed in the article linked above. Those test strips are lovingly called guess strips. Your guess will be as accurate as they are.
