Yes, definitely add muriatic acid with the pump running and retest in 15 minutes. Add acid again as needed until it gets to 7.5. PH tests usually can't read much above 8.0 and it is often much higher than that. Which is why it still reads 8.0 after adding acid. In reality PH might have gone from 8.8 to 8.7. Also, the PH scale is logarithmic the farther out you get from the middle, 7. So, it takes more acid to go from 8.4 to 8.2 than it does to go from 7.8 to 7.6. Keep adding the amount of acid needed to go from 8.0 to 7.5 until PH starts to move into your tester range.
