Hello all,
We're in the Houston area and with the weather warming up slightly, I'd like to test out my pool heater to ensure it works before my PB warranty expires in August. We've heated the spa but it usually only requires 45 mins max to heat it from like 55 degrees to 100. I'd like some advice on how to go about heating the entire pool.
1) Any specific steps I need to follow to heat the entire pool. I'm trying to get the temp to 88-90 degrees. Any lower feels too cold for us with the evening air temps getting down to 60s.
2) Do I need to adjust my pump schedule to run for 24 hours so the pool keeps heating?
3) Currently, pool temp is 60 degrees and air is 75, assume I'm okay with heating the pool. I heard somewhere that at low water temps, a pool should not be heated as the heater will be damaged. Is this true? I'm just curious about this for future winters so would like to get more advice on when not to heat a pool.
Thanks!
Thanks!
