My Hot Tub kept tripping the circuit breaker so I looked online for a remedy and one said to disconnect power to the tub and disconnect the heater and turn power back on when I did nothing happened it didn’t trip and the pumps were working. So I removed the heater and ran my multimeter over the two terminals and it was in range of the Ohms (11) so I put it all back together hit the breaker and it popped immediately there is a small amount of corrosion on the heater manifold so I took out the element checked again with meter and it was in range I then hooked up the element to the hot tub and flipped the breaker ( I do know it’s not a smart thing to do) but it didn’t trigger the breaker so my assumption is that the manifold corrosion is enough to trip the breaker. Anyone have any other thoughts?
