Hi, I have the Jandy Lite 2 Heater. Display is working, it says the pump is running which is correct so its detecting flow. It also knows the temperature of the water. When I switch it to on it does not turn on. Eventually I get a service error code FL3. Which means: flame detected when no flame should exist. Trouble shooting guide says:
I do not see any damage, another site said to replace the board or the sensor. How do I test if the sensor is working? Any other solutions would be welcome. Below is the picture of the sensor.
JANDY R0334300 LAARS LITE 2 FLAME SENSOR
Jandy R0334300 Laars Lite 2 Flame Sensor
Jandy part number R0334300 Pool Heater Flame Sensor Original Jandy Laars replacement part Laars Lite 2 LD and LG (mfg. 2000-2009) Laars Lite (1997-2000) Jandy Lite 2 LJ (2000-pres)
www.yourpoolhq.com
