Good Evening!! I am at my whits end right now and I don't know where to turn. We got a new Jandy heater installed 2 months ago after our original heater took a Crud. Anyway we have only had our pool for 2 years so you can only imagine my frustration.
Here is the issue... when the heater turns on you hear it ignite then it shuts off. My pool guy replaced the ignator rod but then the Jandy tech said we didn't have enough gas pressure going to the heater which makes zero sense since it worked fine for the last 2 years. Anyway we called the gas company and they installed a 2lb gas meter and we had a plumber install a regulator as directed by the Jandy Tech and we still have the same issue. Now of course Jandy is saying there is a problem with the gas line but the gas company took their measurement called the water colum and it was fine. I don't know who to be angry with at this point.
Have any of you had this issue where the heater starts then stops? Eveything was working fine gas wise for over 2 years so how can this have been a problem all along? I am lost.
