There is an Aqualink Rs. The inside one touch controller says the spa is heated to 104 and shuts the heater down. The Raypak heater is set to 104 but when this happens water temp is only 95. Put a thermometer in spa to check and heater is correct at 95. Temp sensor replaced so know its not that. Also calibrated temp sensor though one touch. Can't figure out what is going on.
