Well my heater is leaking. It's a Raypak P-M206 (200 BTU) attached to a 15k gallon fiberglass pool. It is original and is probably close to 20 years old. I am suspecting there was water in it that froze this winter. I'm not sure how, it was blown out with the drain cap removed. Either way, I have a problem.
After I get it open and assess the source of the leak, I may have more questions. Maybe it's something simple. Crossing fingers.
- I am likely going to have to open this thing up to 100% determine that that's the source of the leak. Any other words of advice/wisdom as I tread into these unfamiliar waters?
- Is there a used/refurbished market for these things? I'm likely going to opt for the same model as it appears they still make it or at least very similar in hopes the plumbing and gas line up.
