I have a Mastertemp 400 heater, less than 5 years old. When I heat my spa, the heater comes on, then the burners ignite. They run for about 45 seconds, then they shut down for 30 seconds, then fire up again. Cycle continues until spa reaches desired temp (very slow). There are no error codes, and I confirmed my variable speed pump is running at 50gpm, higher than the listed minimum 40. Is this normal?
