Pool Clown
In The Industry
It doesn't look like (from the picture) you can run the spillway independently from the in floor without physically turning valves. Either one, the other, or both.
That's assuming that the "vacuum line" is the in floor, and the "spa water feature" is the spill over. If you want to run both, there may still be a problem, flow. Your VS pump could probably handle supplying enough water, but the plumbing (size) may not be able to deliver it to both. Not seeing the spa overflow (spillway), i can't tell how much water it would need to flow properly/evenly or "look nice". Not that i could give you a number if i could see it. The in floor needs a certain amount of flow as well to operate properly.
You could spend the time and work all the calculations to see if your system could do it, or you could fiddle with the valves and pump speeds and pretty much accomplish the same thing by eye.
Your best bet for every day use is to run the filter with the in floor open and "crack" the spillway valve just enough to allow some water to the spa for circulation. It probably won't look as nice with just a little water going over the spillway, but you will accomplish filtration for the spa and guarantee enough flow for the in floor . Then adjust the valves accordingly when you have a party, or just want to enjoy the spill over.
Note: Some systems have a "pool" return plumbed into the spa for this circulation. But in your case, i don't think you have one looking at your pic.
