Hey y'all, wanted to check in on a question about our new pool.
We have a Jandy Heat/Chill pump (JRT3000R) and a Jandy JXI 400K BTU Pool Heater both.
We have had differing opinions on the order of the flow.
Opinion 1 - Water flow should go through the Heat/Chill pump before it is routed to the Pool Heater, and then to the pool
Opinion 2 - Water flow should go through the Pool Heater before it is routed to the Heat/Chill Pump, and then to the pool
Any thoughts on this? Which way is better and why?
For any additional context if needed... approx 20K gal pool + large spa, 3.5-5ft depth range, chlorine, north texas area. Wanted to use pool longer through the year so was told the chiller portion of heat/chill will give us some relief on hot streaks due to shallow nature, and heater portion of heat/chill will give us stability of warmer as it cools down, and that the JXI component should help us get quicker to a temperature (like spa, or pool) but is not for maintaining as much as the heat/chill unit will be more efficient.
New to this world and learning!
