I've recently replumbed my Pentair Mastertemp 400 heater with a Jandy valve (with actuator). I wired the valve to the Pentair heater's control board. Everything appeared to be going great upon first use. Before the heater begins heating, the valve opens and water no longer bypasses the heater. However, after the setpoint temperature (102 F) is reached for the initial run, the Pentair's default behavior is to close the valve (entering bypass mode). At this point, with the bypass valve closed, there is no water circulating through the heater - it can't properly measure the temperature. In fact, it was 116 F after the heater cooldown of approximately 1 minute. Therefore, it seems unlikely the heater will turn back on in a timely fashion to maintain the setpoint temperature. Is there a way to rewire the Pentair heater so that it reads from a different temperature sensor located elsewhere in the pool intake plumbing where there is constant water flowing? I know there are probably other options such as using the fireman's switch and using an out-of-band thermostat, however, I'd really like to let the Pentair heater's built-in thermostat do its job. I'm actually surprised Pentair doesn't have this natively solved with their product. My guess is that Pentair's recommendation in their manual is to use an Intellivalve programmed to never be fully closed so that some water continues to circulate. Intellivalves are now a discontinued product! Even so, the Intellivalve is not a true bypass at that point anyway and would allow potentially aggressive water flow through the heater to prematurely ruin the heater core. Any recommendations please?
