- Jul 3, 2023
- 42
- Plaster
- Pentair Intellichlor IC-40
Hi all, family (2 to 3 of us) like to swim for 30 mins or so everyday, so looking to have desired temp (say 82 deg) for a couple hour stretch - say 5 pm to 7 pm every day. Have a 110K BTU Pentair heat pump. Pool is an awkward shape with an integrated spa, so not easy to cover. I am thinking of getting some floating solar covers (5 ft circles) as a test. Peak pool temp these days is in the 70s or low 80 around noon according to Pentair Easytouch but drops off after that. It is below 70 deg when sun comes up.
Whats the best way to operate the heat pump to achieve the desired temp (say 82 deg) for the couple hours every evening?
I currently run low rpm for 7 hours from 9 am to 4 pm and high rpm from 4 pm to 6 pm. How should I change the rpm settings based on use of the heat pump?
thanks in advance for your help!
