bk406
0
Heating a house with a heat pump is an entirely different animal than heating a pool. It takes a tremendous number of btu to heat a pool as compared to a house. At 30 degrees, the btu output of a heat pump would have trouble heating a tub of water.
It takes 83000 btu per hour to heat 10,000 gallons one degree in 1 hour. You lose that much and more heat in one hour at 30 degrees even with a cover. And, I seriously doubt at 30 degrees, or even 40 degrees, even a 120,000 btu heat pump would put out that many btu per hour. So even though the heat pump might pull some heat out of even 20 degree air, the amount of heat lost from a pool in an hour is more than a heat pump can put into the water. It's not that they don't work at low temp, it's just that they cant keep up with the heat loss so all you are doing is wasting electricity.
