Hello I just installed a Intex 18 x 48 Prism pool, I upgraded to the Intex 3000 GPH Sand filter with the 15,000 gallon Chlorine generator . I Am looking at the Hayward HP50AEE heat pump, the pool store says my Intex pump wont even have enough flow to use the heat pump, however based on the flow stats my Filter flows well above the Maximum recommended for the Heat pump... Anyways before I drop $3000 CDN to install this Heat pump I'd like a more educated opinion , thank you in advance
