I am doing an owner build in AZ and I'm wondering if there is a real advantage to heat bending over fittings? Flow vs. repairability? Anyway, any thoughts would be great thanks.
When we installed a long water line at a scout camp, we tossed all the empty beer cans in the trench to aid finding it in the future!For a new pool install, go with the fittings guy. If there are any problems, you would most likely have to change it over to fittings anyway for any repair work.
Be sure to take lots of pics of the plumbing as it goes in, with landmarks in the pics for location purposes should there be any problems. You could also have the plumber put in a "locator wire" along with the pipes for long runs away from the pool.
But it would show up on a metal detector. The PVD pipe wouldn't.But that would not give a good locator signal.......
According to Vinidex, the largest PVC pipe manufacturer in Australia, a 50mm, class 12 (2", actual bore of a class 12 pipe is 53.7mm), 90 degree bend is equivalent to a 2.81m (9.2') section of pipe at a flow rate of 1m/s (3.28 f/s)A 2" 90 is the same as adding 8' of pipe to a run if my memory serves me correctly.
