Just a head's up. Don't let your installer (two different pool stores told me it couldn't be done) tell you that a Hayward VS pump can't be controlled by a Jandy or other third party control panel. Hayward has excellent technical guides showing a number of ways that a VS pump can be controlled by third party controllers.
In my case, the Tri-Star VS900 is set to 'relay mode' (where the third party controller timers are used and the pump only sets the speeds) as opposed to 'stand alone mode' (where the pump timers and speeds are used).
I now have the pump connected to the actuator ports on the Jandy panel so when solar is called for the actuator port not only opens the valve to divert water to the solar panels, but also tells the pump to run at whatever speed I've programmed it. Same with my cleaner actuator port and my deck jet actuator port.
You can also connect the pump to relays in the control panel, if you don't want to use the actuator ports and have other things under relay control (like a booster pump, or some other water feature).
This way, I can have the pump run at a lower speed when I'm not using solar, cleaner or deck jets, and it will automatically switch to whatever higher speed I've programmed for solar, cleaner and deck jets if they are called for, and slow down again when they are not called for.
Here is the technical guide for a Tri-Star VS900, for example, and I know there's one for the EcoStar as well.
https://www.hayward-pool.ca/pdf/manuals/2014-TriStar-VS-TSG.pdf
