I have T-15. First lasted 10 yrs, second 8 (as of today, it's toast). I clean it annually (2p water, 1p HCl); haven't needed to clean it any more than that.
Each year, the HCl solution boils very little when cleaning (so not very much scale buildup). We have well water here, typically battling high alkalinity. Pool volume is 30k gallons (vinyl) and cell is rated for 40k gallons. Usually set 10-20% range. Normally keep the water reasonably balanced, but haven't been fastidious and it's gotten out of whack occasionally (doing a deep clean of the sand filter really makes a huge difference!).
So 4 years running full-tilt is probably a reasonable expectation. Were it my pool, I doubt I'd burn it that hard; however, as they say, your mileage may vary. Your water, your pool may need it. A test kit with a quick chlorine and pH kit like the one that comes in the TF-100 could very well extend the life of your cell considerably (assuming, of course, you use it and adjust the cell's output to keep your levels reasonable).
Troubleshooting guide for the control box (if your cell and controls are separate) ... 1. Turn switch to off, 2. Turn switch to Auto and wait (10s or so) for the relay to click, 3. Push "Diagnostics" button 5 times and wait for the number to stabilize (will show negative), 4. Switch to Super Chlorinate, then back to Auto. If the number still does not match the salt level, time for a new cell.
