I believe I need to replace my 2015 cell. I have a new T-15 Cell and flow switch in a cart and I’m about to hit purchase, but want to verify my thought process.
Opened the pool last week and my SWG was not working – Aqua Rite panel read “No Flow” continuous light. I fiddled around with the flow switch with no success. Plug it in and it went straight to continuous light – No flow. I used a spare telephone wire and twisted the pair of wires to simulate a closed contact, which resolved the “No Flow”. So I think the sensor is bad and needs to be replaced.
Onto the SWG Cell. Using the twisted pair, the Aqua Rite panel would light “Generating” for about 30 – 60 seconds, then both the “Check Salt” and “Inspect Cell” lights would light continuously. I inspected the cell – no build up observed, flushed the cell with water, and reinstalled. This did not solve the problem. Holding the diagnostics button for 3 seconds does not reset the lights. I did try a muriatic acid clean using a the “Kleen Muriatic” b/c Lowes didn’t have anything else. I made it ~ 25% solution, no fizzing, no bubbling, it didn’t seem to do anything, so I’m going to the hardware store today to buy the proper Muriatic Acid (31%) and repeat the cleaning. I don’t really expect a different result.
Water Test Levels
FC: 11.5 (Shock level still decreasing)
CC: 0
TC: 11.5
pH: 7.8
TA: 70
CH: 120
CYA: 60
Salt: 3,000
Aqua Rite Panel Parameters
So I need a new cell and flow switch, right? I’m also upsizing to the T-15 cell since at 24K gals I’m pushing the T-9 cell to max.
Water Test Levels
CC: 0
TC: 11.5
pH: 7.8
TA: 70
CH: 120
CYA: 60
Salt: 3,000
Generating | Check Salt/Inspect Cell | |
Display | 2.00 | 2.00 |
1. Pool temperature | 28 | 28 |
2. Cell voltage | 27.3 | 31.1 |
3. Cell current | 3.22 | 0.00 |
4. Desired Output % | 66P | 66P |
5. Instant salinity | -2.10 | -0.00 |
6. Product name | AL-0 | AL-0 |
7. Software rev | r 1.59 | r 1.59 |
8. Cell type | t-9 | t-9 |
