You are referring to the 24 bolts that attach the top half to the bottom at the flange in the middle correct? I don't think the manual specifies a torque for those. Several owners have expressed that area to be a bit challenging for leaks.
Let's assume you confirmed both top & bottom surfaces are squeaky clean and have no burrs, lubed the O-ring, and have them in position. Once you have all the bolts in place with nuts attached finger tight, I would do the typical "star pattern" across the circumference of the flange in an effort to obtain equal squeeze tightening around the entire flange. I would recommend a simple hand-tight (snug) at first. Do not overtighten or you run the risk of pinching the O-ring too much or creating a leak. Turn on the pump and watch for leaks. If needed, slowly tighten a little more.
For a sanity heck, let's ask
@1poolman1 to confirm.
