So, my wife went swimming today and unplugged the pump since she doesn't like the jets. When I got home I went to get water to test the chlorine and pH, noticed this and plugged it back in. 0 PSI and weak pressure from the return jet.
I tried to reprime the pump but unfortunately I can't seem to find the pressure valve, so whenever I remove the top seal the water just gushes out. I don't have a valve that I can close from the skimmer so I blocked it with a skimmer plug.
I tried letting run for a bit but still nothing. I tried backwashing in case the Sand filter was clogged. It was dirty but not terrible.
After backwashing the water level is a little low on the skimmer but it seemed fine before that. So I might try adding more water but I hate doing that because my well water is alkaline and high iron.
For reference I have an 18 foot Cornelius above ground pool and a Hayward Powerflow LX pump hooked up to a 100 lb sand filter.
