I’m hopeful that someone with a similar setup can assist.
I have a Jandy Aqualink system and understand it well.
My neighbor has a Hayward ProLogic system with 3 single speed pumps and we’re both confused about how freeze protect works there. His PB hasn’t been very helpful and has told him simply ... “that’s how it works”.
This is the issue ...
When the air temperature is below 40oF the pump(s) run *every* 5 minutes for about 1 minute and then typically shut off. Frankly this system is keeping his family and my family awake at night - it’s between our houses. :/
Does anyone have configuration suggestions on how to ...
- lower the freeze temp to 34
- increase the time interval between the pump starting to test the water temperature
- generally reduce the number of pump starting cycles
All help appreciated.
PK
PK
