I have a Hayward Prologic PL-P-4, GVA24 Hayward actuator on a 3 way Jandy valve. I have plugged in the Solar sensor to the Prologic, i plugged the GVA into Valve-3. I can manually activate the valve using the iPhone aquaconnect app. I went into the setting and changed the Solar setting to Enabled, Solar Extended to Enable. I set Valve-3 to Solar as well. In the Settings on the Prologic i set the Solar Temp to 90. My expectation was when the Solar sensor is 8 degrees higher than the Pool water temp it should open the valve-3 and the water should flow to the Solar heater. It doesnt ever open the valve automatically even though it was 11 degrees above.
I then changed the Valve-3 to a timer and went into the Timers menu and set it to open the valve at 12pm-6pm and run at 75%. Worked perfectly.
Why will the Solar not work?
