I’ve had an AGP for about 6 yrs. At the time of install the local building/electrical inspector required my electrician to ensure the water of the pool is bonded by use of a typical copper wire buried around the pool and connected to a stainless steel line that is in contact with the water in my pump. In order to do this the electrician used a product that has a SS winding the fits under the pump basket and has an end that comes out the drain line. In order to seal it the product comes with a compression nut that is supposed to seal things up. In practice the thing has always leaked, either from the compression around the SS wire or from the plug itself because the threads aren’t deep enough to thread into the drain plug hole.
My question, good TFP folks, can anyone recommend a good product that will enable me to properly bond according to local building/electrical code?
Thanks!
FWIW I have a power-flo matrix W3SP15932S/SP1514Z2S4EC
Thanks!
